I am running MC_Home command. If the Position input is 0.0 then the command runs and completes correctly. If the Position is non zero then the command goes into error. I am using motion app 1.12. We are using drives with MPB20 firmware.
I see the same problem also. Here are the error codes from MC_Home and ctrlX diagnostics. I could not find anything in the online help about these codes. We can tell that 0 is succesfully being written to S-0-0052 when 0 is the value for Position. However, as Craig mentioned, any other value causes a severe error.
Thanks,
Brian
with the search function I also did not find the error code 090F2040, but with a look at the error codes of ctrlX MOTION "09" I found also 090F2040.
this bug was fixed with RM21.11.2.
Michael
