11-04-2022 03:36 PM - edited 11-07-2022 09:26 AM
see below
11-07-2022 09:25 AM
For WebIQ licensing via ctrlX license management, some special settings have to be made. Please read the following PDF document:
“WebIQ Installation and Licensing settings for ctrlX” (PDF)
You can find the latest version of the document in the WebIQ download area of the Collaboration Room
How do I get access to the Collaboration Room? (see FAQ)
What licenses do I need for a WebIQ HMI project:
Notes:
Further links to ctrlX licensing:
Get an App and App License via ctrlX Store
Quick Start Guide Licensing Center
First steps after ordering a license
Activate an App License for your ctrlX CORE
Activation of PC based licenses via ctrlX WORKS
Try out ctrlX Apps by means of 10 days trial licenses
11-07-2022 10:03 AM - edited 11-07-2022 10:13 AM
I attached the current version of “WebIQ Installation and Licensing settings for ctrlX” (PDF)
One additional important hint: When you want to connect to WebIQ server running on ctrlX, you must create a special WebIQ Designer shortcut. This is described in the PDF, too. Alternatifely, just unzip "NewWebIQ-Designer-shortcut.zip" and start included script "NewWebIQ-Designer-shortcut.vbs".
05-11-2023 02:44 AM
