07-12-2023 06:11 PM
A customer is asking if there is a process to import the configuration from ctrlX IO Engineering into ctrlX PLC Engineering while offline? So far I have only done it while online, so I would choose "Selectively from ctrlX CORE" here. I assume the offline process would involve "Selectively from file", but I'm not sure where to find or how to generate the necessary file so that I can build DataLayer_Realtime offline based on what was added in the ctrlX IO Engineering project.
Brian
07-13-2023 12:14 AM - last edited on 07-19-2023 11:04 AM by CodeShepherd
Take a look at this post.
11-15-2023 08:21 AM
There is an how to available: "Import EtherCAT IO realtime data offline into ctrlX PLC Engineering"
