Import I/O configuration offline
rku
Is it possible to import an I/O configuration made with ctrlX I/O Engineering to ctrlX PLC Engineering not being online in a real or virtual Core? There is this "Offline from file..." option in PLC Engineering. How is such a file created?
6 REPLIES 6
CodeWasi
EDIT: There is an how to available: "Import EtherCAT IO realtime data offline into ctrlX PLC Engineering"
in case the configuration is already on the control -> download available under:
without the data being available on the ctrlX. Edit the ctrlXIOEng and download the config via "Saving Ethercat configuration...":
exporting command of EtherCat masterexporting command of EtherCat master
if not listed yet, see "Tools" -> "Customize":
export IO configuration settingexport IO configuration setting
Finally the data can be added "offline".
PLC Engineering import EtherCat configuration from filePLC Engineering import EtherCat configuration from file
OK?
Bye
rku
I don't have that "Generate EtherCAT XML" option.
You have add it to your visible menu. See post above.
rku
Yes, I got that. But I can't find it in the Tools - Customize menu. As you can see from my post, the menu contents are different to that of CodeWasi.
I updated the screenshot to make it clearer. The entry is missing in general and you have to add it. Please see post above.
