10-29-2021 02:54 PM
My ctrlX CORE is at 0% available storage. I cannot seem to find a place that can show me what is using the storage (apps, data, logs, whatever). I suspect some of what is taking a lot of space is the logs (I had set up logbook persistance). My questions are:
1. Is there a place where I can see storage used by app or system service?
2. How can I flush the logs (I have turned off log persistance)?
Thank you!
Pablo
11-09-2021 11:17 AM
Did you check if there are many apps in local storage? In the next release (RM21.11) there will be a function that shows storage allocation in more details.
11-11-2021 07:26 PM
I did uninstall a lot of the apps, but that did not clear space immediately. A while after that the free space went up, but I am not sure why (periodic logs flushing task ran and freed up space?)
11-12-2021 07:21 AM
There are some functions which will occupy storage
If you have uninstall apps at the next boot up the control makes a self storage cleaning (more or less succesful at this version) which will free some storage (e.g. deleting the internal snapshots, ...). Thats the reason why you see a went up of free storage after a while....
To start with a "virgin" system with the next release (V1.12 - RM 21.11) you have the possibility to install a system image.
Hope this explanation will clear some questionmarks. 🙂
11-25-2021 04:22 PM
Hi Jochen Mueller,
I have short memory and I want to know if there's some way to delete the things that occuped space, I don't see anything, I mean I deleted all the apps that I can, but I don't know where's the other files to delete them by example temp data from backups or snapshots, also I don't know where can I find the new version 1.12, could you help me?
I'm working with V1.10
11-29-2021 07:38 AM
Hello Jacks
Curently there is now way to delete the "internal" data I mentioned.
With the new release coming in december 2021 there is the possibility to make a factory reset via image update. With this all "internal" temp files/snapshots/... will be cleared.
The release will be available at the collaboration room probably next week...
Jochen
