03-06-2024 09:36 AM - last edited on 03-07-2024 08:30 AM by MichaelB
Hi everyone,
I'm trying to add a couple of SoftMotion CoE axis to a Lenze i700 double inverter, but I found two major issues I can't get around (as far as I know).
The first issue is about Ecat mapping/nodes:
At first, I coudn't add the softmotion axis under the Ecat datalayer node, then i found this thread and, correct me if I'm wrong, in order to add the SoftMotion axis u need to erase every child nodes. Tried and worked, just one big issue: the drive in the linked thread calls the I/O mapping in the parent node, the Lenze i700 calls it in the child node, so once i erase it in order to add the axis, I can't map any Ecat variables. (see some pics)
The second issue is about Softmotion axis "resources": even if I erase the child nodes I can only add just one SoftMotion axis while the drive handles two.
SoftMotion v4.12.00, SoftMotion adaptation v1.20.03
ctrlX PLC & ctrlX IO v1.20.06
If someone can help/explain, Thanks,
03-18-2024 09:58 AM - edited 03-18-2024 10:02 AM
Same problem happened on me. If the device in IO Engineering have two nodes(Parrent Node and SubNode, because of Device Description File?), then after you add the node in PLC Engineering, then you can't add axis for using softmotion. I think this problem only happened on softmotion CoE.
By the way, when I using Panasonic Drive, I can delete the sub node in IO Engineering and then download, then only the parrent node could been added to the PLC Engineering side, then you can add the softmotion CoE axis successfully.
Rexroth AM Drives also have this problem when using softmotion CoE. However, you can't delete the subnode for AM Drives in IO Engineering side,don't know why.
Softmotion: do not matter which version it is, at least from 12 to 15 all have this issue.
Softmotion Adaption: V 1.20.3 and V 1.20.4 all have this problem
ctrlX Works: from 1.20 to 2.04 all have this problem, I think the previous version will also have this issue.
a month ago
Up to now there has not been any support for running CoE axes with CODESYS Softmotion and the ctrlX EtherCAT master. But we released a new bundle of packages (ctrlX PLC CDS_SM Adaption 1.20.4.0.package and CODESYS SoftMotion 4.15.0.0.package) last Friday that will be published within the next days.
4 weeks ago
the update is now available. Link see at "CODESYS - SoftMotion".
