06-23-2023 04:11 PM - last edited on 06-26-2023 07:06 AM by CodeShepherd
Hello Community,
We need to reset the trace and trend graph,
Trace element triggering the reset button does not reset the trace graph.
As for trend graph, i tried following codesys online help (below) deleting the trend recording history, it seems the VisuTrendStorageAccess library does not have the GlobalInstances.g_TrendRecordingManager variable to find the trend recording.
https://content.helpme-codesys.com/en/CODESYS%20Visualization/_visu_trend_programming.html
Anyone know how to reset the graph in codesys?
Warmest regards,
06-26-2023 07:07 AM
Moved to corespomdig Forum CODESYS - PLC Add-ons.
06-26-2023 07:43 AM
Hi.
What is the ctrlX WORKS version you are using?
06-26-2023 09:34 AM
Internal Tracker: CI 680453
06-26-2023 10:15 AM - edited 06-26-2023 10:16 AM
Hi georkueh,
I am using ctrlX Works version 1.20.2.
Also is it possible to extract the recorded datalog file from the trace or trend graph to ctrlX HMI in csv or text file?
Warmest regards,
06-28-2023 09:25 AM - edited 06-28-2023 09:27 AM
Hi Open
The trend can be reset as described with "Deleting the trend recording history".
The trace cannot be reset. It continues to run. You can start and stop the trace, but there is no reset.
06-28-2023 10:16 AM
I think i set my sTrendRecordingName wrongly previously, now is working.
07-04-2023 02:55 PM
Codesys trace supports a command, that saves the data to a file on the development system, f.e.g *.trace.csv as file type.
https://content.helpme-codesys.com/en/CODESYS%20Development%20System/_cds_cmd_trace_save.html
Trend data cannot be saved as a .csv file format/data.
05-07-2024 04:49 PM
