CODESYS visu How to reset trace and trend graph?
Open
Hello Community,
We need to reset the trace and trend graph,
Trace element triggering the reset button does not reset the trace graph.
As for trend graph, i tried following codesys online help (below) deleting the trend recording history, it seems the VisuTrendStorageAccess library does not have the GlobalInstances.g_TrendRecordingManager variable to find the trend recording.
https://content.helpme-codesys.com/en/CODESYS%20Visualization/_visu_trend_programming.html
Anyone know how to reset the graph in codesys?
Warmest regards,
8 REPLIES 8
Moved to corespomdig Forum CODESYS - PLC Add-ons.
georkueh
Hi.
What is the ctrlX WORKS version you are using?
Internal Tracker: CI 680453
Open
Hi georkueh,
I am using ctrlX Works version 1.20.2.
Also is it possible to extract the recorded datalog file from the trace or trend graph to ctrlX HMI in csv or text file?
Warmest regards,
CDSAddons
Hi Open
The trend can be reset as described with "Deleting the trend recording history".
The trace cannot be reset. It continues to run. You can start and stop the trace, but there is no reset.
Open
I think i set my sTrendRecordingName wrongly previously, now is working.
CDSAddons
Codesys trace supports a command, that saves the data to a file on the development system, f.e.g *.trace.csv as file type.
https://content.helpme-codesys.com/en/CODESYS%20Development%20System/_cds_cmd_trace_save.html
Trend data cannot be saved as a .csv file format/data.
