05-07-2024 04:49 PM - last edited on 05-08-2024 07:22 AM by CodeShepherd
I have updated the ctrlX works from v1.18 to v1.20.10, the library visutrendstorageaccess, 4.4.0.0 is not recognized.
When i search for the library source:When i when i open the source library file:
When i open the library source file:
Anyone had this issue? I have attached my PLC project.
05-08-2024 07:30 AM - edited 05-08-2024 07:31 AM
Moved to own topic from "CODESYS visu How to reset trace and trend graph?".
First of all please beware that this is a compiled library so no source code is available. Therefor you get the error message "There is no source code...".
So is your general problem, that you get an exception when running your program in simulation mode?
Did you update all sources to latest one while updating your project? Also visualization manager, compiler and so on? This can be afterwards again via "Project --> Project Environment... --> Set all to newest".
05-27-2024 02:36 AM
Thank you for your tips. The graph object does not work in simulation mode, when logging in to a real ctrlX it worked.
