ctrlX Drive Engineering Local help file by default
YUL725
Is there a way to define the local help file by default  instead of the  Online Help with ctrlX Drive Engineering ?
Thanks!
Jochen_Mueller
Hello YUL725
What do you mean with "define the local help file by default"?
Currently you have two offline possibilities
  • the ctrlX DRIVE offline help. This will be installed if you select the setup option during ctrlX WORKS installation
  • the Offline help installation. Here the online docu will be installed locally and can be configured at the ctrlX WORKS settings. The installation file is available at the extented ColaborationRoom
Jochen
Nice to know.
But another step has to be done. I tried the above mentioned but if I use in a parameter editor window the help it still opens the online help.
You have to activate the following: see screenshot. then the "online"-window opens but with the offline-address.
Regards, Stefan
