02-07-2023 09:36 PM
Hello, I have the following error after I delete EDM element from the functional scheme:
Could someone help me how can I fix it?
And I'm also interested if it is common that software works very slow when I add or remove elements? When I open wiring scheme it takes more than a minute to open the view. We've tried to install software to another laptop, but it was the same slow. Do we need maybe to install something else or to reinstall? I've tried different versions including the latest 8239 with no change of this behaviour.
02-09-2023 07:56 AM
I think I could find a solution. If I delete all EDM elements in the whole project then I don't have this compilation error. So if you need to delete one, you probably delete all and add one less back.
02-09-2023 08:04 PM - edited 02-09-2023 08:16 PM
Hello OpconUser,
great that you found a way.
The explanation is that you have added one more EDM instances than are allowed.
@Dias : FYI, do you have more experiences?
Best regards
Your ctrlX SAFETY team
