SAFEX-C as FSoE master and EtherCAT slave
dhg
As far as I understand, SAFEX-C is capable to be FSoE master and EtherCAT slave at the same time, communicating through the XF28/XF29 port. Correct me if I am wrong.
Apart of the official documentation (programming, installation... manuals) is there any guide to perform this configuration?
David
AllAutomation
Hello dhg,
it is quite simple:
1. SAFEX-C.1x being an EtherCAT slave does only need the ESI-File with the IO configuration of the EtherCAT-Master.
2. SAFEX-C.1x being an FSoE-Master needs only dragging-in of the FSoE-Slave device from the library into the Device/Terminal Scheme
In the case above the first two FSoE Slots in the configuration of the SAFEX-C.1x are used by the two devices shown here.
3. SAFEX-C.1x can be an FSoE-Slave itself in parallel to EtherCAT-Slave and FSoE-Master just by hooking this functionality in the controller's property dialog.
HTH
Best regards
Your ctrlX SAFETY Team
