07-20-2022 02:35 PM
Hello community,
I use ctrlX Works in a virtual machine! After updating from Version 12.1 to 14.1 I always get following error when creating a new project! See attached picture (Pic_1). It looks like the following functions cannot be imported (Pic_2).
I also get an error if I want to insert a template ( in my case the AxisInterface ) see Pic_3.
I have already uninstalled and then reinstalled ctrlX Works. Also a repair installation did not work!
Regards Alex
07-22-2022 11:02 AM
Hello Alex_K,
congratulations - you found a malfunction and I need to report that it to RuD. Easy reproducable.
Since the fix is not yet done, do you mind to operate with ctrlX-Works installation RM2207 coming soon (end of next week) or I over projectarchive in the meantime generated based on my prerevision and you can import.
Please send a note and we can get in contact.
Bye Jens
07-25-2022 11:14 AM
Hello Alex_K,
after intensive discussion and aims to reproduce we want you to check the Installation the ctrlXWorks and included ctrlX-PLCEng installation.
We assume that the VirusScanner has impact on the correct installation routine. Maybe you and view report from the virus-Scanner checking for tags like rexroth / ctrlX ..
But we really want you to
- deinstall your ctrlX-Works 1.14.x
- deactivate the VirusScanner for the time of
- installing the 1.14.x new.
- Check the PLCEng afterwards.
We appreciate your cooperation, since our claim during reproduction differs from case significantly.
Thanks!
07-28-2022 02:55 PM
Hello Alex_K,
regarding Pic3.... please check if the Visu-packages are available.
Bye Jens
