07-18-2022 02:40 AM - edited 07-18-2022 02:40 AM
Hello Community,
I am new to CtrlX PLC programming.
I tried programming a simple ladder program, but however when i tried to download online to the ctrlX drive demo kit it give me an error "ML_AXSVELOCITY"
Anyone know what is the error?
Warmest regards,
07-18-2022 08:20 AM - last edited on 07-20-2022 10:14 AM by HmiGuide
Hello Open
the big question: What kind of error do you got?
next Question: Can you move the axis in vel mode via commisioning dialog?
I have test this with a virtual axis: -> All OK.... (I used structure test, but the FB is the same...)
Following points to mention
Regards Jochen
07-20-2022 05:34 AM
Hello Jochen,
Thank you for your reply,
I am able to move the axis using the CtrlX Motion app.
When i tried to use move velocity function block it gives me an error "ML_AXSVELOCITY". But however the function block for move relative is working well.
Warmest regards,
Open
07-20-2022 06:59 AM
Hello Open
This error message says, that your PLC project version doen't fit to the app version running in the CORE. So please check
If you do not see any different. Please try to crate a new project and see if this is working...
Keep in mind that the velocity mode is new in V1.14.
Jochen
07-27-2022 08:43 AM
I got it working after changing the settings to rotary from linear and setting it to modular.
Thank you.
