Just wanted to show something i found out myself.
I had this error when switching from config to running mode:
Solution:
Create a task for motion manually.
EDIT: maybe someone can confirm if this is the intended procedure from now on.
Cheers
It is a known topic because of an update from RM21.03 (v1.8) to RM21.07 (v1.10) and using the old AppData (active configuration).
See also this topic.
the error message is still shown as before ,after did the action as below picture, so ... why?
thanks a lot, I am clear now ~
