RM21.7 ctlx core motion not switching to running
nishimura
Just wanted to show something i found out myself.
I had this error when switching from config to running mode:
Solution:
Create a task for motion manually.
EDIT: maybe someone can confirm if this is the intended procedure from now on.
Cheers
Re: RM21.7 ctlx core motion not switching to running
It is a known topic because of an update from RM21.03 (v1.8) to RM21.07 (v1.10) and using the old AppData (active configuration).
See also this topic.
sun_lei
the error message is still shown as before ,after did the action as below picture,  so ... why?
Your picture shows that the ctrlXAutomation task was set to a non realtime cpu core (Nr 1). See my working settings below.
sun_lei
thanks a lot, I am clear now ~
