Hello togehter,
how is it possible to run a motion-application programmed in the IDE and another IDE project at the same Time in the ctrlX Core?
Greetings
Yannic
Several ways are possible here. The created files can always be found in the AppData (active configuration) under "scripts/bosch/tiger/..." after you clicked compile:
