I understood that trend variables are configured inside the Recorder Manager and the values are stored inside a sqlite database. How do I get access to the recorded data in case of the WebIQ Server is running on the ctrlX CORE or on a PC? Can I export the data into a csv-File?
You do not have access to the ctrlX file system so you cannot access the database directly.
We are currently evaluating a CSV export functionality as a standard feature of an WebIQ HMI app in the form of a widget.
However, if you require this feature right now we could implement this as a custom feature. If you are interested in this please send me am PM.
Thanks for the fast answer 👍
The realization of the application is planned for the middle of next year. If the feature would be available then, this would be sufficient.
It will be availabe we are working on it
Kinde regards
webiq-eg
