Hej,
I have applied for a runtime license with 500 tags through the ctrlX configurator.
After recieving and activating it in our licensing center, I obtain a .csv file ("ActivatableItems.csv").
I assumed this was the license, but when using it with the ‘Upload License’ feature under ‘Offline Activation’ in WebIQ Designer, I am told that it is of the wrong file format.
Next, I have downloaded the Activation File, and made a profile in MyWebIQ, where I used it to add my device (a ctrlX CORE), but it states that I have no active licenses here:
How do I proceed from here?
Also, when using the ‘Online’ Activation’ feature, I get the following:
Thank you very much.
licenses purchased from ctrlX should be enabled directly in your ctrlX as far as I know. However, for that you have to connect directly to ctrlX CORE by starting WebIQ Designer with the corresponding command line parameters --ws-host and --ws-port as outlined in the manual.
Licenses purchased for ctrlX cannot be used with a local WebIQ installation that does not connect directly to ctrlX CORE. For that you have to purchase separate WebIQ Designer licenses directly from Smart HMI.
Regards,
Sascha Kimmel
In addition, runtime licenses cannot be used with a local WebIQ Designer installation at all.
