01-30-2023 11:31 PM
Has anyone communicated with a fanuc robot and Ctrl X over Ethernet/IP? I'm trying to set this up but running into an error saying "invalid connection size".
One thing I've seen is that the Codesys EIP settings only can group the data into 8 bit (byte) chunks while the Fanuc robot groups them into 16 bit chunks. I tried to specify the size in CtrlX to match the overall size, but this is still not working.
Has anyone done this before?
Thanks,
Dylan
02-02-2023 02:30 PM
Hello
Normally when you configure 2 Byte for one Word, like you explain, it should match and work. Is there more detail diagnosis in the Ethernet/IP Scanner or Adapter status page?
Is a device description EDS file available for the Fanuc robot?
Can you share settings of the generic device in the ctrlX PLC Engineering project or a project archive.
The configuration or info about the Fanuc Ethernet/IP configuration will be helpful as well.
03-30-2023 05:23 PM
is your problem solved?
kind regards
3 weeks ago
I have the same problem like this. But I used Allen Bradley IO coupler.
The error is the same, is there any experience could share to us?
Thank you.
3 weeks ago
@DavidChuang please do not ask the same question in several forums.
You topic will we discussed in "ctrlX connect AB IO coupler through EtherNet IP".
