11-01-2023 08:07 AM
In another question here (https://developer.community.boschrexroth.com/t5/ctrlX-PLC/quot-Erzeugen-der-Bootapplikation-felgesch...) I was asked to ensure that I am using the latest CtrlX WORKS version (which seems to be 2.02.1) ... however I have done a lot of searching here. Either I'm doing it completely wrong, or I don't have access to that version.
What do I need to do and where can I get that version?
Chris
11-01-2023 05:21 PM
You should be able to gain access to the collaboration rooms following the instructions found here. See "Be part of the pre-release program".
Release v2.02 can be found at this path.
11-01-2023 09:45 PM
Ok ... so that's ctrlx core and it's apps, right? ... So I've updated my PLC to that version ... I was left in the impression that I should install CtrlX WORKS in version 2.02 ... Isn't CtlrX WORKS the thing you install on a windows PC, which contains the engineering environment, the virtual PLCs and the App build VMs?
11-02-2023 08:17 AM
Hello cdutz
You have to update your complete system to the version 2.02. Means you have to use
All the stuff you find at the link you have used.
Jochen
11-02-2023 09:19 AM
Ok ... I think I know what my misunderstanding was:
I was thinking that if I have access to 2.02 for CtlX CORE and the apps and these are not officially released yet, that I must also have access to the CtrlX WORKS 2.02 ... but seems that was not the case. So I requested access and I really hope I'll get that approved soon ... SPS in Nürnberg is coming close and if I can't get my CtrlX running soon or our demo at the Bosch Rexroth Booth will be pretty boring.
11-03-2023 08:18 AM
@cdutz Please do not ask the same question in several posts. See answer to your same question in topic "Erzeugen der Bootapplikation felgeschlagen".
