Error 404 in datalayer when using namespace attribute
AndyL
When using variables with {attribute 'namespace':=''} in the plc the datalayer goes down with error code 404. Is this a known issue or it is not prohibited to do like that?
Kind regards
Anders
PedroReboredo
Moved to area ctrlX WORKS.
Jochen_Mueller
I have tried it with the version 01V06 (RM20.11).
If I use the namespace attribute my variables doesn't appear in the datalayer. So it seems we have a problem. I forward this issue to the development department...
Funktionality with RM21.11 (V1.12)
  • Add "Symbol-Configuration" to application
  • use {attribute 'symbol' := 'readwrite'}
  • use {attribute 'namespace' := 'Application.xyz'}
the first part of the namespace string must be the name of the Application (here Application :-))
The following parts defines the namespace with which the GVL appears at the datalayer. The basic path (plc/app/"Application-Name"/sym/) is always fix. Means you can only influence the path after the basic path.
Jochen
