Before applying my purchased licenses to my ctrlX CORE I wanted to see what is possible if the 10-day temporary usage rights is switched on. This allowed me to use Motion, IDE, Node Red without licence. But PLC and EtherCAT still showed the "not licensed" message, so I could not do anything with these critical apps. Is this a bug, or is it really the case that there will not be a trial period for those apps?
Brian
Hi Brian,
are you talking about the Trial License you activated in the Licensing Center?
Please send some screenshots / more information.
Cheers, Pedro
Hi Pedro,
I'm sorry for the confusion, I meant to say "10 day" not "10 hour". I will edit the original message after this reply. This is activated in the licensing area of the ctrlX CORE. Please see screenshots below.
Brian
After following path above, Motion is working (for example), but PLC and EtherCAT are still blocked:
Hi Brian,
thanks for the additional information, now I understood.
The temporary usage rights are kind of an emergency mode, and can only be activated once. This should also include licenses for the ctrlX EtherCAT Master and PLC App. I've opened a ticket to solve that. Sorry for the inconvenience.
But, have a close look under the christmas tree... 🙂 You should really use the Trial License for your use case which you already have within the Licensing Center, and can assign to your device (map entitlement). I double-checked that, both PLC and EtherCAT Master app licenses are included.
Hope I could help, if not give me a sign.
Regards,
Pedro
Hi Pedro,
Thank you, I will check into the trial license in the Licensing Center. Good to know PLC and EtherCAT Master will be added to temporary usage. I think this feature will be used quite frequently until more people get familiar with the Licesning Center.
Brian
hi pedroReboredo
I have another problem about the 10-day "tempprary usage rights".I have a new ctrlx core and purchased licenses .
first,I applying apart of licenses and it's ok.
secondy,I enable the 10-day "tempprary usage rights"
third,I appying all of license,then,an error is occur,following screenshot is error message:
then refresh web ,web display the following message:
meanwhile, three more license in license file:
then,reload system is necessary and cann't applying all of licenses again(because the same error will be occur)
thanks for your support.
@LZT I will get in contact with you directly and we will investigate this.
Please don't mix up the two different possibilities of getting temporary licenses:
thanks for your answer.
enable the temporary usage rigths was a unexpected operation,it won't happan again!
it has been sloved temprorarily,
thanks for your support again
