Hello StefWi,
since the SAFEX-C.1x products are not yet in General Sales state the access is controlled via Collaboration Room.
To get there ...
- Click that link ctrlX AUTOMATION - Collaboration Rooms | Bosch Rexroth AG.
- A login-dialog is displayed.
- Either you have a Bosch ID already you can access the collaboration room and search for a directory called "ctrlX SAFETY".
- If you find it, you can enter the "SAFETY_Engineering-Apps" directory and download the provided versions of ctrlX SAFETY Engineering.
- If you don't find that, you do not have the necessary access rights. Please apply for them with your Bosch Rexroth Sales contact who will link your E-Mail address registered with your Bosch-ID through to the DC-AE/PRM product management. The responsible product manager will add your ctrlX SAFETY role within 24 hours.
- If you don't have a Bosch ID please use the login dialog and register for the Bosch-ID
- After that follow the above procedure
Finally you arrive in the collaboration room, where you have access to two main sections:
- SAFETY_Runtime-Apps (say certified firmware releases, including relevant device description files)
- SAFETY_Engineering-Apps (ctrlX SAFETY Engineering releases)
- SAFETY_Templates are not filled, yet.
HTH StefWi 😊
Best regards
Your ctrlX SAFETY Team
