Error using Q0.9_PP
Error using Q0.9_PP
bclapperton
I get an error when I try to use Q0.9_PP. When I try to drive this output I get an error (red flashing) on the SAFEX.
I'm trying to use the four 2.0 Amp outputs to drive four Hydraulic coils. Can this be done? The manual is not very clear.
I first made a program to drive a hydraulic coil using Q0.8_PP. I connected one side of the coil to Q0.8_PP and the other side of the coil to 0Volts. This output goes on and off with no errors. Then I made only one change to my program to re-allocate the same output block to Q0.9_PP. Then I changed the coil wire to Q0.9_PP. When I turn on the output it comes on for about 1 second then there is a fault and red flashing.
Program is attached.
I have High Side turned on on the C.12
BRamos
AllAutomation
Thank you @BRamos !
HTH, @bclapperton
