10-19-2022 11:51 AM
Hello to all of you,
I'm posting this message because I'm new to JSON files and would like an explanation. Basically, I have a camera that can recognize car plates and when detected, it sends a JSON file to the automaton. My question is: is it possible to retrieve information from this file and use it in my PLC program to control a pump for example.
Thank you very much for your answers,
Kevin
10-20-2022 08:17 AM
Yes, it is possible in the PLC. It depends on the environment what to do:
06-12-2024 10:08 AM
