Problem trying to connect to the PLC
Fred74
I am working with CtlrxWorks 1.6.0
When I open Indralogic from the webInterface I got this screen
The only way I have is to press the right button.
After pressing it I got the following screen : no possible to go online with the PLC see the follonwing screen
How can I get rid of that?
I tried to cancel the right field but nothing is working.
I tried also to stop the virtual control
and also tried to reboot the PC
No way.
Thank you very much for your support.
Frédéric
FooFighter
Hello Frédéric,
in Version WRK-V-0106 there exists a bug opening a synchronized project from the control in the webbrowser opend via the IpV6.
A workaround is to start the browser with the IpV4 address.
The second problem is that the PLC Address of the control is not set correctly. Try to enter the IpV4 address into the field below the control in the communication settings page (double click on the controller in PLC Engineering).
The third problem can be solved by activating encrypted communication for the control. (Should be activated by default).
Refer to Encrypting Communication, Changing Security Settings
Regards, Oliver
