07-03-2024 12:23 PM - last edited on 07-04-2024 07:06 AM by HmiGuide
HEllo,
I am looking for information about the different setting which are available in the plc Task especially the Motion Task.
The first 2 External event are available in ctrllxCORE 2.6 and can be used directly = Good.
If we want to use the plcEvent7 like in the past, we have to add it inside the scheduler.
I didn't find any documentation explaining the differnece between :
What are the difference between each other (incl PlcEvt7) ?
Thank you
07-05-2024 07:34 AM - edited 07-05-2024 09:01 AM
Quick explained the new events will be used for automatic configuration of the scheduler and will integrate in the execution order of the ctrlX AUTOMATION task if corresponding app (e.g. EtherCat mster) is installed. The older events must be added by hand.
Information will be added to the officially documentation in the next weeks.
