04-02-2024 04:02 PM
Hello ,
I am using ctrlx PLC 1.20.4 and works 1.20.2 . I try to connect modbus communication via IL_ModbusTCPClient function block . In which Enable is true but InOperation is not true. I am not able to communicate with specify address but, i can ping this address via command prompt. Previously it was working fine but, now it is not showing InOperation true . Please see attached picture for your reference and give me solution.
04-03-2024 07:23 AM
When you can't connect you should check the following:
You said it was working. What did you change since it is not working anymore?
04-03-2024 07:49 AM
Good morning
See if these manuals on Modbus communication between XM and ctrlX Core is helpful.
We have even used this to pass states from the IOs in Ethercat to the XM
Best Regards
Jordi Laboria
E-Mail: jordi.laboria@boschrexroth.es
DCET/SLF4-ES
