01-03-2022 09:57 AM
After updating to the last 1.,12 CtrlX Works and Indralogic PLC vesrion I could not load and find the following Indralogic features:
1. Trace
2. Visualization
3. Symbols
When I try to open a 1.10 project I got the message you can see in the attached file. The message says tha tI should load the project with PLC version 1,10 ( of course before it was working ) or load the missing 1.12 Indralogic Codesys packages.
But where could I found the packeges that must be loaded to return to the working situation ?
How could solve this problem ?
Many thanks for your help
Giuseppe
01-03-2022 02:13 PM
to identify this issue please answer the following questions:
In any case, I recommend to you to do a repair installation. IF this doesn't solve the problem you may forward your project to our support.
kind regards
01-03-2022 02:20 PM
below the answer to your questions:
1. Before the update I use the versio 1.10.6
2. Now I updated to 1.12.2
3. No, even in a new Virtual Control I could not use Visualization, Trace and Symbol
Question: to do the repair I should download the CtrlX verisione 12.2 from our App Store and install ut again ??
Many Thanks
Giuseppe
01-03-2022 03:55 PM
I downloaded the CtrlX installation file version 12.2.2 from our store and repared my installation and now all the features are working again.
Many Thanks
Giuseppe
01-03-2022 04:36 PM
Thanks for your effort!
kind Regards
04-04-2022 08:07 AM
Having the same issues....!
