08-24-2023 03:58 AM
Hi Community,
I am new to using CXA_SocketComm TCP.
I manage to established connection from ctrlX to a TCP device. However i did not receive feedback from the device after sending a string. (see attached)
Looking for advice.
Warmest regards,
08-25-2023 07:36 AM
How to test if my TCP client is working?
Are there tools to host TCP server on my engineering PC and try sending a string from my ctrlX to my TCP server hosted on my engineering PC?
Warmest regards,
08-25-2023 09:25 AM
I created some examples for communication via TCP between ctrlX CORE and ctrlX COREvirtual. See "Communicate between a ctrlX COREvirtual and other applications [DOCU]". There I am using Node-RED but PLC works in a similar way.
Which function blocks exactly are you using in your example? Normally you have a TCP server on one side permanently running and a client connected to it waiting for getting data.
08-29-2023 03:49 AM
Hi CodeShepherd,
I am using IL_TCPConnectionAsync function block library.
Thank you for your tip we tried setting up TCP communication in Node-red, connection is established however when we attempt to send a string it did not send to the device and no feedback from the device.
We solved it by using Telnet communication in Node-red. It is unsure why it is behaving this way.
08-29-2023 07:44 AM
Good morning, not if this is what you are commenting on. I pass you a document on communications in general and another on communication between XM and ctrlX Core in NodeRed using the IL_TCPCyclic module
Best Regards
Jordi Laboria
E-Mail: jordi.laboria@boschrexroth.es
DCET/SLF4-ES
