06-28-2023 10:09 AM - edited 06-28-2023 10:10 AM
Has anyone already experienced GS1 XML with CtrlX Core?
Goal is to use CtrlX Core as a gateway between an automated system and a WMS (Wharehouse Management Software).
Data whould be read/written from/to machine thanks to OPC-UA Client or Server App and converted to GS1 XML protocol to fit with the WMS requirement.
Any hints or apps to get this operating?
Thanks
07-21-2023 04:48 PM
In general you can send each type of file also XML to any target using ctrlX CORE.
Could you describe what exactly should happen in your "gateway". Which data is coming from where and how should it be processed?
