Embed IoT dashboard in web page using iframe
Sgilk
Frequent Contributor
I am trying to display a grafana dashboard in my WebIQ application via iframe. I found a couple of problems with the Grafana configuration that I don't believe can be modified with this version of the IoT Dashboard (1.20.0+9.3.6).
First off, embedding is not allowed, so iframe will not work here.
Also, anonymous authorization is disabled, so authentication will be required to display dashboards.
Is there any plan to allow .ini configuration changes to the official IoT Dashboard app?
nickH
Hi @Sgilk
its allready possible to modify the grafana.ini. Do you use the version 1.20?
MauroRiboniMX
Contributor
Hello Sam,
It should be possible, modify the grafana.ini in the active directory!! But don't forget to save and reboot 😎
Sgilk
Thank you guys! I was not aware this was modifiable in active configuration.
