Does anyone know how to configure Azure Iot Hub for NodeRed?
tpage
Looking for information on how to correctly configure the Azure Iot Hub for NodeRed.
As this is mostly no ctrlX AUTOMATION related topic please feel free to have a look the official Node-RED homepage to check for possible integration.
Sgilk
Contributor
I was able to publish data to an Azure IoT Hub via Node-Red over MQTT protocol using the attached flow. I referenced the Azure configuration tutorial below.
Azure IoT Tutorial : IoT Hub | Stream Analytics |Time Series Insights | SQL
In the Node-RED flow, I used the following open source nodes: https://flows.nodered.org/node/@nodecolor/node-red-contrib-azure-iot-hub
This is a fork of the main branch since I found there was an incompatibility with the current version of Node-RED.
I used the following tool to view the MQTT telemetry data: https://github.com/Azure/azure-iot-explorer/releases
