06-27-2023 06:43 PM
I am trying to display a grafana dashboard in my WebIQ application via iframe. I found a couple of problems with the Grafana configuration that I don't believe can be modified with this version of the IoT Dashboard (1.20.0+9.3.6).
First off, embedding is not allowed, so iframe will not work here.
Also, anonymous authorization is disabled, so authentication will be required to display dashboards.
Is there any plan to allow .ini configuration changes to the official IoT Dashboard app?
06-28-2023 08:17 AM - edited 06-28-2023 09:00 AM
Hi @Sgilk,
its allready possible to modify the grafana.ini. Do you use the version 1.20?
06-28-2023 08:58 AM - edited 06-28-2023 09:39 AM
Hello Sam,
It should be possible, modify the grafana.ini in the active directory!! But don't forget to save and reboot 😎
06-28-2023 03:23 PM
Thank you guys! I was not aware this was modifiable in active configuration.
