EtherCat Modul Adjust parameters
Engi
i´m using the S20_EC_BK Ethercat Fieldbus coupler with an S20-AI-4-UTH to read the values of an Thermocouple Type K.
Now i need to change the parameterizion of the UTH-module.
How can i achieve this via the ctrlX I/O.
Thanks in advance.
cc2go
two possibilities, to configure the module
  • ctrlX I/O Engineering with the "Startup Parameters" on the S20-EC-BK, it's explained in chapter 7 "Startup parameterization" of S20-EC-BK docu R911385711_02.pdf
  • use of the PLC library CXA_S20 (available with v1.8.0 or newer)
Thanks a lot for the fast answer.
It’s working now perfectly.
