Add IO-link device to Rexroth S20 module
OpconUser
Hello. I have Rexroth S20 IO-link module and I would like to add an actuator to it.
I have IODD xml description file from actuator's manufacturer. Unfortunately I couldn't find any button to add a slot or something like this. Could somebody help with this topic?
Sozu
Currently we do not support IODD files for our S20 IO-Link module.
Thank you for the answer!
How can we communicate in this case? Is there any possibility?
cc2go
Process data communication is possible without the IODD.
The porcess data mapping, where your data are, you can mostly find in the docu of the IO-Link devices.
Depending on the EtherCAT IO-Link Master, it's possible with the manufacture tools to set parameters in the IO-Link devices.
cc2go
With ctrlX Works v1.18 we provide with the CXA_S20 library a function block to configure the ports of the S20-IOL-8 module with the S20-EC-BK
