06-15-2023 10:48 AM
What does the setting "Activate output stage compensation meaning" at the PWM settings mean ? It is not described in the P-0-0016 Bit 5. (ctrlX DRIVE)
06-15-2023 05:06 PM
It smoothes the current loop.
Normally this function should be used and therefor be checked in the menue.
