06-15-2023 11:05 AM
Hallo Everyone,
I am planning to use 5 Dopple axis Inverter in my upcoming Projekt but i have some question regarding it.
1) Is Power supply integrated in XMD ? I think XCD Converter have intergrated Power supply but i dont know about the XMD?
2) If Not, which Power supply can be more useful ?
It would be helpful if you guys can show me some Example with circuit Diagramm of Power supply with XDM.
06-15-2023 05:04 PM
XMDs are just inverters which either need a XVE/XVR/XCS or XCD or a 3rd party device (like e.g. a battery) as power supply.
To suitably size the power supply unit you best use IndraSize to calculate each of your axes and then look what device provides the needed infeed and back feed power.
