09-06-2022 10:18 AM
Hi.
Is there any known working third party motor and CtrlX drive combinations that have been tested? Overall is there some restrictions or something to point out when using third party motors?
09-07-2022 08:01 AM
We already successfully controlled different asynchronous motors similar to our MAD motors from e.g. Lenze, some standard asynchronous one like from e.g. SEW, Nord, VEM and SIEMENS, both in open loop and closed loop. Similarly we successfully made servo motors (equivalent to our MS2N motors) work like from e.g. SIEMENS, Lenze, Schneider, ELAU, Fertig motors and Merkes. And we used ctrlX DRIVE in conjunction with direct driven motors (torque and linear motors) from e.g. HIWIN and Etel.
Only restriction at the very moment is what encoders fit to ctrlX DRIVE and that 600 Hz motor output frequency are not exceeded.
09-12-2022 01:19 PM
