Functional package with ctrlX Drive
Toadwart
The functional packages ML, MA, TF will not be available, correct?
smc
Yes, they will no longer be available as you are used to from the past.
Drives_Uwe
But function wise they will be available again in a similar way:
- pre-configured ready-made functions from Bosch Rexroth
- programming of OEM based functions (on own OEM base)
- programming of OEM based functions in including Bosch Rexroth libraries
- PLC programming based on IEC 61131
JohsH
Hello Uwe,
In addition from this topic.
A function as 'Axis error correction' in the SRV → Functional package "Servo function"  in the Indradrive.
For the ctrlX drive: will that be a Runtime-option, or must the Core do the job? And if the Core has to do the job, will that work if I use a thirth party EtherCat Master ( Beckhoff Operating modus: Cyclic Position Control)
Regards Johs Heijmink
Drives_Uwe
With ctrlX DRIVE there is now only the so called "productivity" package available. This is an option. The today functions are the following:
Mind that you can activate only in summary 8 so called performance points as shown in the screen shots before.
