05-23-2024 04:39 PM
I am looking to find this command in a ctrlX Drive with ctrlX Core.
Configuration :
- X3 : 2.04
- ctrlX Drive : 4.02
I try to write this command (C3300) in the Ethercat with my program but an error occurs.
If I try an other command (like C0300), it works.
What can I do ?
05-24-2024 07:32 AM
Please give us some information what the "ErrorID" and "ErrorIdent" is, to check what is happening.
Which function block is used for writing the parameter/executing command? I guess "IL_ECATSoeCommand".
What is current state of drive when command is executed?
05-24-2024 08:17 AM
Did you checked by Drive Engineering (parameter editor) that the S197 (command C3300) is available in the drive?
05-24-2024 09:12 AM
In Drive Engineering, I am not able to find S197, it looks like it doesn't exist in the Drive.
05-24-2024 09:21 AM
06-10-2024 09:20 AM - edited 06-10-2024 09:21 AM
I have tested it with 0404 and S197 is available. See attached screenshot
