Profinet availability
Servodude
Hello all,
It is in another post mentioned availability of Profinet for the ctrlX Drive in April 2022, anyone who can confirm if this still is valid ?
Also will their be ready made functionsblocks and documentation to integrate the drives in the TiA-portal from Siemens?
best regards
6 REPLIES 6
Drives_Uwe
Yes, PROFINET is already available as beta series prototype by now and will be officially released by April 2022.
The planning is to have function blocks for TIA portal available, not by April 2022, but later. Exact schedule not clear, yet. Depends on first customers showing interest in the function.
Will the P-4077 and P-4078 the same as at IndraDrive ? Is the parameter channel also usable ? Regards, Stefan
At the very moment (in the beta release) and as well in the coming release beginning of April 2022 the parameter channel is not supported, yet.
P-0-4077 and P-0-4078 will be same as in existing IndraDrive solution.
Note: My comment was wrong: Instead of P-0-4077 and P-0-4078 one has to use S-0-0134 and S-0-0135.
Dear Drives_Uwe, can you give an update about the availability of the Profinet release and control blocks.
Is there anything available yet?
Drives_Uwe
As already told: PROFINET is released since April 2022. Beginning of August 2022 function blocks and samples for TIA portal will follow.
