01-20-2023 03:05 PM
Where I can find information regarding the firmware function "adaptive velocity control loop gain"?
02-02-2023 05:31 PM
The functionality is the following:
- Definition of 2 speeds where adaption of regulation loop settings takes place
- Definition of adaption factors for both P-gain and integral action time
See example:
05-16-2024 06:25 AM
the above means it only make up the parameters S100 & S101 for the different velocities configured in the X_Axis respective. do not determine the the S100 & S101.
the adaption level will be as per the individual Y_Axis set for P-gain & I-gain. pls confirm.
