03-06-2023 07:39 AM
Hello CtrlXDrive Team
I have a question,In my project I used double Axis CtrlxDrive,Now one of the CtrlXDrive Axis has been broken.I want to know if it possible to specify the EtherCAT address?
When I deleted one of the CtrlXIO configuration,the address will Automatic sorting.
I don't want to delete one of the broken axis configuration ,I just want to use Parking Axis funtion?But it is not possible.
How should I do?
03-06-2023 01:41 PM
You can not associate profile, and this axis is equivalent to a virtual axis.
03-09-2023 03:55 PM
At the moment the EtherCat address is always auto incremented, so it will be resorted when changing the topology in ctrlX IO Engineering.
There will be a new feature in the next version 1.20 that drives can be identified via their names instead of logical address.
I did some test some time ago and used successfully parking axis mode of the ctrlX DRIVE. What means it is not working on your side?
04-17-2023 04:34 AM
Hello
In my current project I used CtrlX Works 1.14,in the fueture when i changed to version 1.20,should i need to changed all APP to 1.20?
In my project ,the drive appeared F8122,So i gussed it will no succussed to parking axis mode.
04-17-2023 06:47 PM
Please send the drive parameter file in format "all parameters" to us. The "parking axis" command should work.
