09-13-2023 08:17 AM
I am now copying an image file into a .snap zip, but I can't read the image, why is that?
What should I do to read this file?
thanks in advance!
09-14-2023 04:26 PM
How do you pretend to be able to use it if you are writing it wrong?😎
Basically you have to use the OS module to load correctly the env variables like $SNAP
Waiting for a feedback
09-18-2023 08:10 AM
Thanks for the heads up, I was able to access the image files I needed by way of absolute path
