X3Plus connection problem
JHU1XI1
The PC is directly connected to X3plus and cannot be searched. If it passes through a switch, it can be searched.
I don't know what caused this. Can someone help me?
Thank you in advance.
5 REPLIES 5
MauroRiboniMX
Contributor
Use a proper cable! Probably you are using a twisted one or so. With the "green" ones happens often. Simply the switch is able to set it correctly.
Mauro
JHU1XI1
Hello Mauro,
I am using a green cable and will replace it with another cable for testing tomorrow. I will share any new information with you.
Thank you very much for your prompt reply.
Poooom i got it 😏. I've lost 4hr with a customer once.
Any news???
JHU1XI1
I replaced the network cable and found it normally.
