09-14-2023 02:54 PM
The PC is directly connected to X3plus and cannot be searched. If it passes through a switch, it can be searched.
I don't know what caused this. Can someone help me?
Thank you in advance.
09-14-2023 04:21 PM
Use a proper cable! Probably you are using a twisted one or so. With the "green" ones happens often. Simply the switch is able to set it correctly.
Mauro
09-14-2023 04:33 PM
Hello Mauro,
I am using a green cable and will replace it with another cable for testing tomorrow. I will share any new information with you.
Thank you very much for your prompt reply.
09-14-2023 04:42 PM
Poooom i got it 😏. I've lost 4hr with a customer once.
09-15-2023 02:23 PM
Any news???
09-16-2023 08:02 AM
I replaced the network cable and found it normally.
