How to modify script files online in solution folder
zhenhui
I want to modify the python script in solution folder online, is there any tools available?
6 REPLIES 6
nickH
Re: How to modify script files online in solution folder
you can access the active appdata of a ctrlX CORE via WebDav. Please have a look at this this post.
If you want to access this file from a self-created snap, you can have a look at this post
zhenhui
Thanks,
The links for WebDav doesn't work. Got the right link after searching "WebDav". Links for solution post .
Jochen_Mueller
Alternative you can use the textual coding of our IDE app. Here you have the possibilty to open, modify and save online your pyton file in the active configuration....
Keep in mind for this you have to buy a license. But in my opinion it is worth to spent the money....
zhenhui
Hello
Thanks a lot for your suggestion.  Textual coding is easy to use for editing scirpts.
The question is that in my virtual ctrlX, the IDE app always crush down when edit script under textual coding page.
I will use it when it's more stable (maybe after this release).
We are not facing any breakdowns. Can you tell us which version of the system apps and IDE app you are using?
zhenhui
I got the problem in V1.12 several mothons ago. I will check if it works on RM 1.16 for the recent days. Thanks.
