07-04-2023 02:59 PM - last edited on 07-17-2023 02:39 PM by CodeShepherd
A customer want to use somekind like a setup file in micro SD card to do a setup of new devices (device configuration, plc program, etc.).
Does WebIQ App support this feature? So after the setup process, the WebIQ Project is loaded and ready to be used.
07-05-2023 09:22 AM
This are 2 different items:
07-17-2023 02:38 PM - edited 07-18-2023 01:44 PM
As far as I know WebIQ is not participating in the configuration management of the ctrlX CORE so the standard mechanism of exchanging the app data cannot be used.
07-18-2023 11:37 AM
In WebIQ you can import and export projects from both the project list inside WebIQ Designer and the Runtime Manager in the browser.
However, copying the settings (autostart projects etc.) is not currently supported. In any way, you'd still need a different license for a different device.
So currently this kind of setup has to be done manually on ctrlX.
